Perform this procedure to configure the VLAN feature on an Extreme Integrated Application Hosting (IAH) port.
  1. In the navigation pane, expand Configuration > Edit > Insight Port.
  2. Select the IAH port you want to configure.
  3. Select the VLAN tab.
  4. Select PerformTagging to enable tagging.
  5. Select DiscardTaggedFrames to discard tagged frames.
  6. Select DiscardUntaggedFrames to discard untagged frames.
  7. Select UntagDefaultVlan to enable the Untag Default VLAN feature.
    Important
    Important
    You must enable tagging on the IAH port before you enable the Untagging Default VLANs feature.
  8. In DefaultVlanId, enter a default VLAN ID.
  9. Select SpoofDetect to enable spoof detection.
  10. In PrivateVlanPortType, select a type.
  11. Select Apply.
VLAN Field Descriptions
Use data in the following table to use the VLAN tab.
Name
Description
PerformTagging
Enables tagging (trunking) on the Extreme Integrated Application Hosting (IAH) port. It can belong to multiple port-based VLANs and a VLAN tag is inserted in every frame it transmits. If it is not checked, the IAH port is an untagged (Access) IAH port. The default value is different for each IAH port.
VlanIdList
Shows the VLAN ID to which the IAH port is assigned to.
DiscardTaggedFrames
Enables the functionality to discard tagged frames received on the IAH port by the forwarding process, for untagged (access) IAH port. The default is disabled.
Enables the functionality to discard untagged frames received on the IAH port by the forwarding process, for tagged (trunk) IAH port. The default is disabled.
UntagDefaultVLAN
Enables the functinality to untag the frames forwarded to the default VLAN, even if the IAH port is tagged (trunk port). The default is disabled.
UntaggedVlanIds
Shows the untagged VLAN IDs associated with the IAH port.
DefaultVlanId
Specifies the VLAN ID assigned to untagged frames received on the IAH port that match no policy-based VLAN to which the EIAH port belongs.
SpoofDetect
Enables spoof detection on the specified IAH port.
PrivateVlanPortType
Specifies the following:
  • trunk: tagged IAH port.
  • isolated: Only private VLANs are permitted on isolated IAH ports.
  • promiscuous: Only private VLANs are permitted on promiscuous IAH ports.
  • none: default value.
